Company Logo (800) 853-2651 Shop Now
190xt
STUDIEDIESEL63
01-19-2023 09:59:15
Hello, I know every machine has good and bad points,but have no experience with Allis,and came across a seemingly decent 190 xt and was wondering what good and bad points about these tractors are?Around 3500hrs.factorycab I think,Thank you for all your opinions.
farmersamm
01-24-2023 20:14:09
 Re: 190xt in reply to STUDIEDIESEL63, 01-19-2023 09:59:15
[quote="DrAllis"](quoted from post at 20:49:02 01/24/23) Quoting Removed, click Modern View to see
You should consider yourself blessed, that you've lived long enough to see it.
Any day above ground is a good day.
DrAllis
01-24-2023 19:49:02
[quote="farmersamm"](quoted from post at 20:31:10 01/24/23) Only complaint I ever had with mine, was the power steering.
I've been in the tractor repair business nearly 50 years now, and never heard of one person having TWO 190XT's that drove poorly down the road, and not get them fixed !! So, it sounds like the power steering cylinder just needed a seal kit when you turn the steering wheel multiple times with not much happening. And secondly it also sounds like the front wheels needed a tape measure used to set the toe-in. Any 190 XT drives just as good as any other tractor if it is right. There. You're fixed !!
This post was edited by DrAllis on 01/24/2023 at 08:11 pm.
farmersamm
01-24-2023 19:31:10
Roading it was a dangerous affair. The steering didn't respond well. Wasn't "tight". It took multiple revolutions of the steering wheel to keep it in a straight line. 2 revs one way..... .2 revs the opposite way. They have a mind of their own, and would veer in any direction at higher speeds. Consequently, the only way to travel with either one, was on the dirt roads that have little traffic, and at lower speeds.
I had this problem with both of the 190xt's I own. Never got around to fixing it, because the tractors were mostly used for loading, and feeding hay, in one location. I only had to road them a couple of times a year. At low speed, around the dry lot, it wasn't a real issue.
DrAllis
01-19-2023 15:27:08
A 190XT diesel was a 5 bottom tractor for sure back in the day. However, it needs good rear tires full of fluid and 400 lbs of front end weights for a 5 bottom plow. So, unless you're farming a whole bunch of acres, maybe settle for a 4 bottom plow. Don't worry about the rear axle size. The original was 2 3/4" and the later was 3 1/4". It only indicates what age the tractor might be. There was NEVER a problem with the axles. They just chose to make an improvement.
DrAllis
01-19-2023 12:23:03
3500 hrs on the current hour meter. What do you want this tractor to be used for ??
STUDIEDIESEL63
01-19-2023 14:12:40
 Re: 190xt in reply to DrAllis, 01-19-2023 12:23:03
5 bottom plow,baler duty,small disc,small field finisher,manure duty,most anything around a farm. Yes 3500 on hourmeter. It's about an hour from home,and have only so far looked at couple pics.So don't know if hours are correct. Pics look decent but need to go look at it
BonaparteSouth
01-19-2023 14:53:32
 Re: 190xt in reply to STUDIEDIESEL63, 01-19-2023 14:12:40
if going with SMALL disc and field cultivator think about just a 4 bottom plow. i assume not many acres and more able to handle in TOUGH conditions!! check to make sure it is a newer model with 3 1/4 inch rear axles. series III would be an added plus.
old
01-19-2023 10:14:43
Check the transmission in all gear both going up and down hill. TheXT190 is known for jumping out of gear
