Wd45 step one.
Pulled the WD 45 over to my little garage to get working on it. Pushed it up to the door by hand but couldnt get it pushed over the little hump into the garage even with the CFOs help. Oh well I will get my skid steer out tomorrow and push it in.
Will the engine spin over?? If it will pull the plugs out put it in gear and hit the starter button. I've loaded many a tractor on a trailer by doing that and as long as you only spin the engine for a short time you can move it many many yard
Hi old. The engine is not stuck. My trailer has a winch on it so I can pull tractors on to it. The tractor has been sitting long enough I want to change the oil in it before I crank it over and put some oil in the cylinders as well. I have used the starter on tractors to move them short distances before and it does work well. Thanks.
If your worried about dry cylinders put some oil in each cylinder then spin it over to get it into the shop
(quoted from post at 19:43:18 01/15/23) Pulled the WD 45 over to my little garage to get working on it. Pushed it up to the door by hand but couldnt get it pushed over the little hump into the garage .....
I know what you mean! I have pushed more tractors than I could ever count into my shop by hand.
They always come in harder than they leave :)
I always found it easier pushing them in, front first, rather than rear first.
