Yes, you either need one-way spool valves, or you need to plumb the second work port from the valve back into the reservoir.
If you just leave the second port capped off you will be deadheading the system when lowering the loader. That will cause the oil to flow through the relief valve. Lowering will be slow and the oil will quickly get hot.
Use separate spool valves for each function and eliminate the splitter valve. Plumb the 3pt up with down pressure.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
