Posted by pete 23 on March 04, 2015 at 08:58:27 from (50.33.21.76):
In Reply to: 706 trans noise? posted by Jrw013 on March 01, 2015 at 18:58:48:
You are talking about a clunk with clutch engaged. At that point the throw out bearing should not be touching or turning unless you have no free play on clutch. You also say the noise sounds like near the clutch pedal. That would be rear of speed transmission or range transmission. I would make sure you have free travel on clutch pedal. Then put speed transmission lever between 2nd and 3rd gear which will be a neutral. No detent there so you have to feel your way. This will stop all speed transmission top shaft gear movement and mesh with lower gears while stopping all turning of range transmission. This should help you pin point area of noise.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
