Farmall Tractors Discussion Board
IH Lo Boy 185 clutch/transmission problem
Posted by Mark Liptak on January 24, 1999 at 13:32:14:
Help...I own a 1974 LoBoy 185 with a Johnson workhorse loader.
Was clearing some snow last week. The machine was running fine. When returning to the barn, I got off the tractor, leaving it in neutral, to close a gate behind me. When I got back on, the tractor would not move. Could shift into any gear, forward or reverse without the clutch. When shifting into a gear you could feel a very small amount of torque going to the rear wheels, but not enough to move the tractor. I also found one sheared bolt in the snow beneath the tractor. I've removed the top cover to view the pto and drive shafts, clutch, throw out and pressure plate assembly. Seems to be working OK. Linkages appear OK, pressure plate stops spinning when clutch depressed. Throwout bearing quiet. Clutch pad can be seen spinning in its assembly. No burning pad smells. All appears intact.
Is the bolt I found a coincidence? It has 1/2" head. It was clearly sheared recently since the shear surface on the bolt is not rusted.
Have I blown something in the rear end? Is there something in this system the failure of which is known to cause this symptom? It's such a good old simple design, I'm a little puzzled.
Any advice before I start to tear this apart would be greatly appreciated.
Mark
Post a Followup
: Re: IH Lo Boy 185 clutch/transmission problem
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
