The negative side of the battery should have a heavy battery cable going from a quality battery terminal to ground (preferably on a starter mount bolt. This battery cable should be at least 2 gauge wire. It supplies the complete ground system for the tractor. No "extra" wires should be between those connections. (I think this is the main issue) From the positive terminal of the battery there should be one battery terminal only hooked to the same size 2 gauge cable, no other connections. The other end of this cable goes to the starter relay (solenoid it is often called). That relay should have 4 terminals 2 big and 2 small. The small terminals are labeled S and I. (If only 3 all is well) The S terminal goes to the push button for starting, 12 ga is good. The big terminal close to the S terminal goes to the above mentioned + battery cable. That big terminal also has a #10 wire hooked to it going to the amp meter (only there). The Other big terminal on the relay goes to a metal connector attached to the starter input terminal. The "I" terminal on the relay goes to the ignition coil + side. It is to bypass the ignition resistor giving the coil full voltage. If this is not there we will worry about it later, it is not needed if the coil is a full 12v coil with no resistor required. Get this wiring correct and lets go from there. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
