Posted by steelfronts on February 13, 2015 at 19:10:30 from (71.10.136.41):
In Reply to: w-12 help posted by farmalldanny on February 13, 2015 at 14:02:03:
Most likely its a combination of the float level being too high and the needle and seat leaking a little bit. The fuel pump works by spring action on the diaphragm. The push rod from the cam only loads (cocks) the spring which pushes on the diaphragm pushing the gas into the carb. After you shut it off there can be one push left in the pump which then pushes past the leaking needle and seat resulting in your problem.That fitting on the front top of the tank is only a fancy elbow not a return
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
