Posted by Kevin on February 04, 2015 at 15:57:25 from (174.236.6.92):
A few days back i had some farmall a governor questions. I got down to the shop to tinker with it a little. Issues are i suspect im not getting full rpm and the first half to 3/4 throttle range is no responsive. Previous owner had a spring between carb flange bolt and governor arm pulling tension on it but it would always idle high however did turn more rpm. I removed that spring knowing it is not suposed to be there and am now looking to solve the problem correctly. Tried adjusting the rod between carb and governor arm as suggested. With tractor off i removed the linkage, moved the throttle to wide open position the adjusted the linkage so the carb is in the wide open position and the pin slipped through the yoke easily to re attach the rod to governor arm. Only took a half of turn and nothing changed. Just checking if i did this right and what do i look for next?
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
