Where do you hear this KNOCKING , is it a lower end knock or is it mid way up in the block?? or is it a top end knock?? Bottom end like said below check the bottom end for a loose rod mid wya up then it could be a wrist pin bushing or just a piston looser in the bore then the rest or it could be a broken piston skirt. as for a top end knock then you may have something inbedded in the top of a piston If it is a wrist pin bushing they can run a long time with that . a broken piston skirt NOW i would start to worry as the rest of the piston could finish breaking and then you will end up with and inspection hole in the block that you really don't need. If it is a lower end failure here again it can get costly really fast, so a pan gskt will do two things either you will see what is wrong and be able to corret the easy problems or it will give you some piece of mind for the short term.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
