My guess is that somewhere in the life of the donor tractor it had the ring gear replaced and it was replaced with the gear that was used on tractors up until the 404 series. If the ring gear is not in like new condition you can assume that the tractor was run with that ring gear not causing problems.
Check the tooth engagement of your drive in the replacement ring gear. It will most likely work just fine as long as the ODs of the ring gear is the same. The tooth engagement is pretty loose between the drive and ring gear and it s not uncommon to find a couple drives with different amount of teeth being used on the same ring gear. That is the case of drive number 1939109. That is a 9 tooth drive that was replaced with a drive with 10 teeth during the production run of the 656 tractors. There was no change in ring gear when the drive was changed on those tractors.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
