Two things here before you start pulling those sleeves. Check the sleeve flange protrusion over the top of the block. You can do that with a simple feeler gauge and a flat chunk of iron. This is a reference to make sure the new ones don't protrude higher than old ones which has been a problem lately with new parts. Then make darn sure your pulling plate is not larger than the outside diameter of the old sleeve. It probably has thin wall sleeves already and they are only 1/16 in thick. Originals were l/8 inch t hick. You want your puller to be a few thousands of an inch smaller than the sleeve. Another thing, when you get the bores cleaned out good, try the new sleeves at same temperature as the block. They should start into the bore a little ways. I always select the best fitting sleeve for each bore. Some will be looser and some tighter. Then you can freeze them if you like, I never do because I want to know how hard that sleeve fits into the bore. Too tight, no good, too loose, no good.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
