Posted by The tractor vet on December 12, 2014 at 07:24:59 from (104.179.81.68):
In Reply to: 300U clutch posted by jeffcat on December 11, 2014 at 18:35:24:
Here is a trick i have used , The cover plate bolts are little SHORT 1/4 inch bolts and do not give you any wiggle room so ONE at a time remove one bolt and get ones that are about a 1/4 x1 bolt and put that in where you removed the one also to aid in this deal there are three shipping bolt hole in the cover and if and again i said IF my old memory has not gone completely i think they ae a 5/16th by one with a flat washer this will pull the pressure plate back against the cover plate and remove the spring pressure . IF the sprag is good you will be able to only turn the T/A flywheel one way so just work around it and once you have removed all the short bolts and replace to the longer ones just to holt it in place then you can take a pry bar and pop the disc loose from the flywheel. Once it loose then just replace the short bolt back in and remove the shipping bolt readjust the linkage and work it . NOW due to age ware and tare most times the BOOK INSTRUCTIONS for adjusting the linkage will not get the job done and here it comes down to a FEEL adjustment and you will have to learn that one for your self.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
