Posted by Jim Becker on December 02, 2014 at 07:34:47 from (173.84.240.213):
In Reply to: Farmall A seals posted by HenryO on December 02, 2014 at 07:17:50:
It depends on how deep you want to go to replace seals. If you change all the seals in both final drives and the ones on the sides of the differential, the answer is YES, it takes 3 or 4 per side.
The ones on each side of the differential are easily seen and replaced once the final drives are removed. There is one on the upper shaft in each final drive housing that can be seen once the brake drum is removed. If you change these, be sure to get the brake drum good and tight when you replace it. There is one on the outer end of each axle shaft. Replacing it requires fairly complete disassembly of the final drive. I wouldn't do it unless it was actually leaking. If you have a seed drive, it will have the fourth seal on that side.
There is an exploded view in the parts catalog, a manual you should have before doing much work on a tractor. An online copy can be found on the CaseIH site.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
