The 656 has a hydraulically engaged PTO like the larger tractors. You will need the engine running to check it. Using a pipe wrench will only tell you if the PTO brakes are working.
You can see the IPTO drive gear between the pressure plate and the release bearing if you remove the bottom cover and look up there. You should be able to see if the splines are chewed up.
I once drove a nail in between the worn out splines on a tractor to allow it it be driven a couple miles to the shop. Not a good solution but it did the job. Made it more difficult to split though. :lol:
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
