Posted by pete 23 on November 23, 2014 at 11:40:31 from (74.33.82.156):
In Reply to: 656 hydraulic problem posted by 656 Gasser on November 22, 2014 at 16:04:03:
No plastic suction tube on a 656. It is steel. There is also a section of hose connecting the return from aux valve directly into the suction tube to reduce cavitation. Some times the hose gets kinked, some times it bursts, sometimes people take it off completely. I doubt this is your priming problem though. Most likely restricted filter, weak pump, poor seal of suction tube on the pump or the o-ring on main suction tube which is in the split between transmission and rear case. You can look into rear to check hose and grab suction tube to see if it mount has broken loose through the 3rd arm plate. Far as amount of oil coming out with filter, the suction tube is above oil level so you will only get about that quart or so that you got, normal. If you over fill you will partially drain rear with filter off. If you see any crud on screen at filter that tells you oil needs changing and filter. The oil only goes through the screen with cold oil or plugged filter as it is easier to go through screen than paper when cold.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
