I had a Super W-6 that had the same problem. Normally, I am a purist and will not switch to 12 volts and I don't like to do generator/alternator swaps. In my opinion, it spoils the original look of the tractor. So, out of pure stubbornness, here is what I did:
-Replaced the Super W-6 starter with a WD-6 starter which is 12 volts so it avoids the harsh engagement of using a 6 volt starter with a 12 volt battery.
-Removed the Super W-6 generator, removed the pulley and end plates from the generator. I installed these on a WD-6 generator and then re-installed the WD-6 generator on my Super W-6.
-Replaced the Super W-6 ignition coil with a 12 volt coil from a W-400D.
-Replaced the Super W-6 light bulbs with 12 volt bulbs.
-Swap the 6 volt battery for a 12 volt battery.
This wasn't difficult to do if you have the right parts tractor and a little bit of mechanical/electrical aptitude. It would be the most expensive 12 volts upgrade if you had to buy all of the parts. The end result was fantastic. A tractor that looked original, exempt for the bigger WD-6 starter and the 12 volt battery. It would start easily at -15F without the block heater being plugged in.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
