In spite of what some say here, you can have either positive or negative ground with a 6 volt system. The starter, generator, or voltage regulator doesn't care once the generator is properly polarized to match the configuration of the battery connections. I've run my Super A with the 6v pos to ground, then swapped to negative ground and it worked just fine for 2 years each way. Just recently put it to 12v with an alternator, and both I and it are much happier.
Anyway, to polarize the generator, take a piece of 12AWG wire with a short bit stripped from each end, and with one end on the "A" (larger) terminal of the generator, momentarily touch the other end to the "Bat" terminal of the voltage regulator, or the NON-grounded terminal of the battery (or starter lug). It should spark. All it takes is a 'touch'.
To check your generator, disconnect the wire from the "F" (smaller) stud of the generator, then with the engine running at least half throttle, take your length of wire and with one end on the engine block (or other good 'ground'), put the other end on the "F" terminal. Have a helper look at the amp gauge - it should show a charge.
There is a good possibility that when you jumped the 6v with a 12v battery, you cooked the regulator.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
