Posted by Drew 16 on November 17, 2014 at 08:17:15 from (83.200.193.176):
Hello, all.
Whilst being a Ferguson owner my self, my next door neighbour (who speaks only French) has a German-built International 724 with a D-239 plant. Since the day he paid over the market value for it, he's had various troubles, none of which, I've re-assured him, are insurmountable. Consequently, with my encouragement, he's ploughed on with a progressive overhaul, whilst still actually using the tool. However, the time has come to face a certain fact that the awful rattle on uptake is not down to his gearbox main-shaft; rather that he has issues with his big-end and/or main bearings. It's not that the engine has ever lacked power or been a challenge to start, just that it has this cacophony on uptake.
So, head off, sump likewise, and timing-chest removed, and he's faced with cam gear, idler, pump gear and the smaller sprocket on the crank. Piston #1 currently sits at TDC, with the locator pin for the crank pulley at 180-deg south. This I've told him, for all my experience of IH, is important to note, as he has an engine which is/was well-timed, with #1 where it needs to be for setting-up. But, of course, that crank needs to come out, and the pistons with it, and I fancy it will be a bit of an art to throw back in in exactly the same position, dowel 180-deg south and #1 at TDC, which, if so, would change nothing regarding the smooth timing he has always had. I focus on the locator dowel as there are no other obvious timing marks on the crank gear, that I can see from the observations I've made.
So, boiled down, do the D-239 knowledgeable ones on here think that the less-than simple replacement of the crank as it currently stands is possible without shaking about cam/idler/pump gears, and will alter nothing, or does wisdom say remove the idler, fit the crank and then position everything as if it was a complete re-build (which it isn't really, as there is no actual need to remove/replace the functioning cam and pump)?
Kind of sounds like I'm asking what are all the timing alignment marks at #1 TDC, doesn't it? :D
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
