Posted by Janicholson on October 30, 2014 at 08:58:39 from (199.17.6.160):
In Reply to: Super H distributor posted by chuckj1954 on October 30, 2014 at 08:35:20:
Were it mine, I would put the shaft (apart) in a good lathe and use a dial indicator th assess the lobe geometry. (bent or worn or made wrong to begin with) If the squareness is OK, but off center, it will never give reasonable results. If the cam is actually off center, the magnet that fits on the cam will also be off center and thus have variable distance to the pickup module. Finding a different cam shaft should be pretty easy even a worn shaft that is evenly dimensioned from centerline, (try Bates Equipment in Indiana) will be OK for replacement with an electronic system (this site has them for 6v Pos or Neg ground) It will run so much better when timed correctly on each cylinder that it will be a miracle. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
