Posted by John T on October 09, 2014 at 05:17:14 from (216.249.72.121):
In Reply to: 200 coil posted by dewy on October 09, 2014 at 03:51:03:
On a 12 volt tractor you obviously use a 12 volt coil or else use a 6 volt coil PLUS an external series voltage dropping (12 to 6) ballast resistor.
A 12 volt coil may be labeled "12 Volts" or "12 Volts NOT for use with ballast resistor"
HOWEVER if its labeled "12 volts for use with ballast" IT MEANS WHAT IT SAYS and requires a ballast
Have you checked battery voltage?? If the voltage regulator is bad it may be raising battery voltage to 15 volts or so which will raise coil temperature plus it will cook the battery eventually plus acid will boil over.
A 6 Volt coil (needs ballast on a 12 volt tractor) has a LV Primary resistance of around 1.25 to 2 ohms while a 12 volt (no ballast required) will be more like 2.5 to under 4 ohms.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
