you are on the right track. Remember, the carb fuel bowl MUST be full of fuel for these to run. The IHC #10 carb (which I believe to be the right number) can be VERY cantankerous. However, when they are right, they will fire right up and run......and run well.
make sure the fuel bowl is full. There should be a drain on it. crack the stopcock valve open and see if you have fuel. if you are using a gravity feed, if it is dry, the float needle valve may be stuck shut. If you have fuel, then it should fire and run.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
