The alternator output post and the #2 terminal should have battery voltage on them at all times. The #1 terminal is controlled by the switch or what ever other method you have to provide power to excite the alternator. The voltage on this terminal will depend upon which method you used to control the back feed when the alternator is charging. Ideally this voltage should be at least half of battery voltage. If you use a diode in the #1 terminal circuit the voltage should be very close to battery voltage. If you use a light bulb or a resistor the voltage will be less. I do like to see less than about four volts with the switch on. The lower the voltage on the #1 terminal the faster the alternator will have to spin to begin charging. Once the alternator starts to charge there will be charging voltage at the #1 terminal so the alternator will continue to charge even at engine idle.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
