You said nut on range transmission main shaft. That would be the pinion shaft and just tighten the heck out of it as it has to hold the spacer, carrier and pinion bearing tightly together. Lot of them work loose over time. If you mean the nut on lower speed transmission shaft, well you will get a hundred different answers on that one. I tighten it, back it off just a little, with cleaned threads and extreme Loctite plus the locking washer. Reason to back it off is those lower gears find a pattern and if you tighten it down tight you will get a noisy speed transmission and they will eventually loosen up again anyway even with the heavy spacers over time. On the oil circulation, I never drilled any hole in housing, just knocked the plug out of housing. It doesn't circulate as well as with the hole but it works fine and a whole lot of tractors are running around that way.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
