A 102 should have battery ignition, battery, points and coil (at least mine does). Are points gapped? take off the cover and turn it over and see if they're opening and closing. While cranking spray gasoline or starting fluid into and see if it tries to run, if not trouble shoot your fuel system. Check for spark at the plug (if nothing else clamp the plug to the lifting lug hook up the wire and crank it over, should have a nice blue spark, while doing this you can also see if it's got compression (is it pumping air out the plug hole?)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
