Posted by Owen Aaland on September 08, 2014 at 16:39:39 from (216.47.34.49):
In Reply to: Hot Coil and voltage posted by clint s on September 08, 2014 at 13:25:54:
The voltage at the distributor with the ignition on and engine not running should be either battery voltage or no voltage. This is true whether or not you has a ballast resistor in series with the ignition feed on the coil. With the engine running the voltage will be constantly changing between those two values. The voltage you are seeing indicates that the points are closed about half the time and open about an equal amount of time. Your meter is not able to react to the changes in voltage fast enough so what you are seeing is an average of the two values.
To determine whether or not you should have a ballast resistor you need to measure the resistance of the coil. If the resistance is about 1.5 - 2 ohms use a ballast resistor of the about same value. If the resistance is 3.5 - 4 ohms do not use a ballast resistor.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
