Posted by SDE on August 17, 2014 at 16:31:16 from (174.124.63.138):
I assume that to correct this problem, I will need to pull the head, pull out the piston and remove the sleeve. If the bore in the block is ok, then what do I do? Is the sleeve suppose to be a tight fit? If it is too loose, is that why the coolant is getting in the oil? If I get it fitted properly will the leaking stop? I don't think it is a head gasket problem, because I have not lost much coolant and it has not been over heating. Thank you Steve
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
