Posted by Owen Aaland on August 12, 2014 at 13:29:54 from (216.47.34.49):
In Reply to: 1568 Questions posted by John M on August 12, 2014 at 05:31:34:
The engine runs on four cylinders, two on each side, until the engine load reaches 20%. As the load increases the other four cylinders start to fire until at 80% all cylinders are getting equal amounts of fuel. Above 80% load it runs evenly on all eight. Which four cylinders that are working all the times depends on when the tractor was made. Part way through production they changed which four cylinders ran all the time. Both systems fires the two center cylinders on one side and the end cylinders on the other.
The main reason IH gave for running on only four cylinders at idle and light load was to insure that those cylinders that were working would have enough load on them to keep them warm enough to clear up smoke from a cold cylinder.
Starting with ether assist is standard procedure at temperatures below 70° F. Push the ether assist button after getting the engine to crank over and continue to feed ether after it starts until if no longer pushes out white smoke.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
