Hi as Jim said could be PTO dive splines on pressure plate. I assume you checked transmission fluid level. You can remove inspection plate from bottom of clutch housing and look at PTO drive shaft that is outer shaft that is splined and goes into pressure plate splines. You can mark the PTO shaft with a bright magic marker, then start engine and look to see if PTO shaft is turning at engine speed. If PTO shaft is turning, then check hydraulic filter but it should bypass if filter is clogged. Next would be hydraulic pump problem or MCV valve problems like stuck relief valve or blown O-rings.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
