Posted by JakeBrake on August 04, 2014 at 16:54:42 from (69.126.179.144):
So I got a new 6V battery, new coil, new plugs and plug wires, changed out the points, condenser and distributor cap on my H. Now she turns over pretty well, until I run the battery down trying to start her of course.
I got the tractor to start and she was actually running pretty strong, sounded like it at least. Except it would only run at 1/4-1/2 throttle, if I touched the throttle otherwise or if I put the tractor in gear and tried to move it, the tractor would die. I have to believe that it is a carb issue, but Im not positive.
Also, when it was running there were sparks, only a few, flying off the motor, coming from somewhere in the neighborhood of the manifold. I know that I need a new valve cover gasket, could that be my issue??
One other thing, the air breather bottom has a line in it that says oil level. Should I be filling the breather bottom up to this line with oil? If so, is just 10w30 good or is there some other oil I should be filling it with.
Thanks. All advice, suggestions, and help much appreciated.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
