Feel the coil when it stumbles. If it is way hot, the issue might be that it is a 12v coil for use with a ballast resistor (which means it is really a 6v coil). If given 12v it can heat and break dowm, causing misfire. If the coil is warm and not way hot, My guess is fuel related. Put a can under the carb, and drain fuel for at least 2 minutes. If the flow slows down you could be having a blockage at the tank to sediment bowl connection, r in the screen at the carb fitting. The fuel cap has one or two vent holes in the top. Make sure the vents are open. Jim
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
