A rubber O ring will NOT work. A GOOD carb repair kit will have the new packing included.
Are you 100% certain the engine is from a Farmall H? An H carburetor has only the fuel drain on the left side, and the load metering adjustment screw, which is also on the bottom, but points towards the rear, at a downward angle. The other "screw", to the left of the drain plug, is NOT a screw. It is the clamp nut for the main metering stem. It is NOT an adjustment. It will leak fuel if it is loose, and it CANNOT be tightened from outside the carb. The clamp nut is meant to be held in place, while the main metering stem INSIDE the carb is tightened. There IS a gasket under the clamp nut, as well as under the hex head of the metering stem. DO NOT mess up that clamp nut. It is no longer available, anywhere, at any price.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
