First thing, make sure there's supposed to be a gasket. AFAIK those valves are only sealed with Orings, and a gasket will spread the metal parts too far apart and weaken the seal.
That said, I'd also look for blockages in the system downstream that are preventing the oil from returning to the reservoir and causing the pressure to build up.
From the way it sounds the relief valve is not working and if you put it together so the gasket can't blow, something else will blow. Probably, something expensive and/or no longer available as a replacement part.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
