A 1948 would have a cutout, not a regulator, unless it was converted.
A cutout is manually controlled by the light switch. Four positions: Low charge, High charge, Dim light, Bright light.
If you replaced the cutout with a regulator, and did not rewire it correctly, I would imagine that something akin to what you're seeing might happen.
First off, is the meter reading a charge correctly, or is it showing a massive discharge?
Second off, how do you know the charge is not reaching the battery? The only way to know that is to use a voltmeter across the battery terminals. If it's charging as hard as it says it is, the battery voltage should be over 7. If it's only around 6, then it is not charging.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
