Posted by Peter Hoyt on July 09, 2014 at 20:43:04 from (67.241.76.247):
I did a valve job plus rings & rod bearings. compression 105 in all 4. oil pressure 75. water is getting into oil and cyl #1 so I suspect either cracked block or seeping around head bolt; does that make sense? no visible leaks of water or air around head gasket.
It runs rough at high idle under no load. all new ignition parts, now it runs better under load at low rpm when cold but gets worse when warms up. no power at high rpm despite choking and playing with carb adjustments. seems to be getting plenty of fuel. can make black smoke with choke
I plan to get a carb rebuild kit and try that but running worse when hot scares me along with water in oil.
Also I was wondering if I should pull the distributor and examine shaft. If worn could timing jump around?
If anyone has ideas or suggestion please reply or contact me at ph44@cornell.edu.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
