This is for a rowcrop 300 or 350, haven't done a 300U engine.
To install 300 or 350 engine in a H
1. If you are planning on using the 300/350 live pump be sure to use the timing cover and related parts for 300 or 350, SH or late H (older H bolt holes are different).
2. Use the H fan, 300/350 fan is to large in diameter.
3. Use the air cleaner & pipe from air cleaner to carburetor for a SH, the one for an H is to small for the 300/350 carburetor.
4. Use a 300/350 or SH flywheel and a SH clutch plate and pressure plate if you are going to pull it hard (H flywheel, clutch plate and pressure plate will work but is smaller, H 10”, SH/300/350 10 ½” ).
5. Use H governor or use throttle shaft from H governor in 300/350 governor.
6. Have to convert vent from back of head on H to vent from valve cover for 300/350.
7. Change oil pressure fitting from H onto 300/350 block before installing side rail channels (fitting is hard to change after rails are installed).300/350 had small line from block to gauge.
This post was edited by Dave S. at 12:41:00 06/25/14.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
