Posted by John T on June 24, 2014 at 06:50:10 from (216.249.72.121):
In Reply to: 6 to 12V conversion posted by henryv11 on June 24, 2014 at 05:49:03:
Questions Questions, lets take them one at a time:
Questions:
1. Does the new alternator single terminal get all the wires in the diagram that lead to the generator cutout? That is the YB back to the ammeter; the YR to the main light switch BATT; and the Y to the 12v horn?
The main big single wire output lug could/would feed YES basically all (12 Volts) that was wired to the BAT side of an old Cutout Relay. That would be the LOAD (NOT Battery/Starter) side of the Ammeter,,,,,12 VDC to light switches BAT INPUT etc. Sometimes those loads are fed off the LOAD side of the ammeter but that's electrically the same as BAT on a Cutout Relay or the LOAD side of an ammeter. That's where the BAT on the cutout wires anyway but now the alternators main big output stud.
"If so, does the alternator charge the battery through the circuit running back to the ammeter and to the + side of the battery?"
The alternators charge gets to the battery to charge it VIA THE AMMETER. The LOAD side wires to the alternators output while the SUPPLY side gets to the batterys ungrounded post often where the big battery cable attaches to a starter switch or starter solenoids input. It needs wired at right polarity or would read bass ackwards.
2. My 20 amp ammeter has the pass-through type of connector, not separate terminals, but my wiring harness has terminal connectors. I assume most/all new ammeters will have terminals? Is a 30 amp ammeter enough? I have a Nu-Rex 12v neg ground alternator, but it's been years since I bought it and don't remember the specs. Probably 60 amp max output or something.
A typical new ammeter will have + and - terminals which I call the LOAD (output and BAT on Cutout or new alternators output) and SUPPLY (input from battery) Sure ideally a 50 or 60 amp ammeter might be used but a 30 will suffice. It may peg for a short period after start up depending on battery condition. Trouble with a 60 is after start up the needle may not move much. A 20 amp may be a bit too small to handle an initial 50 or 60 amp surge but Ive used plenty of 30 amp meters on a 60 amp alternator never had a problem if you don't mind the needle possibly pegging after start up.
Anyone willing to jump in? Also, please...let's not hijack this as to why I should stay on 6v +grnd. :-)
If you insist lol your tractor your choice NOT any of ours
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
