You can eliminate the resistor for the ignition system by using a 12 volt coil but you will still need some way of keeping the #1 terminal of the alternator from back feeding the ignition circuit and preventing the engine from shutting down when the switch is turned off.
This can be done with a diode which stops any current from coming back out of the alternator to the ignition circuit, a resistor which drops the voltage of the back feed too low for the engine to stay running, a light bulb which can serve as a charge indicator and also lowers the voltage, an ignition switch with separate accessory and ignition feed terminals, or a separate source to energize the #1 terminal. A separate source could be a switch that you manually activate to provide the power or it could be done automatically by using a switch closed by engine oil pressure.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
