Posted by jdemaris on May 27, 2014 at 16:02:17 from (70.209.129.221):
In Reply to: Re: B275 leaks . posted by Glenn D on May 27, 2014 at 10:41:53:
I forgot that I modified mine 20 years ago. I took off the old plunger-fuel pump that is bolted to the side of the injection pump. I made a steel plate with a drain valve and a filler hole with a pipe plug. Note to the upper left is a unmachined boss for a dipstick. Those pumps on some tractors had dipsticks to check the oil level but wasn't used on the B275s for some reason. To drain - when you still have the original plunger-pump -you just unbolt that pump. I assume seeing how hard CAV made it to fill that pump box - they figure letting it run with just diesel fuel as lube will be OK. Can't overfill since you've got that excess tube. On Ford tractors with Simms in-line pumps - I've seen several run out of oil in that box and seize. By the way. I took my plunger pump off when I first got the tractor in an attempt to make it start better. I added an electric pump that made no difference. What really makes these tractors start better - is to add the new 12 volt Mercedes-type glow plugs. Makes a HUGE difference. I've had two B-275s with the in-line pumps and also two newer ones with the rotary CAV pumps. The later models always have started better. The different pumps seem to make a difference.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
