Ok, that makes sense. I"ve had it apart before and just put in back the way it was but that doesn't mean it was right! When I look at the ipto shaft starting at the gear, I should have the gear, then bearing retainer washer(which I thought was a shim), then bearing, correct? Which way should the bearing be, the snap ring closer to the gear or bearing cage? Right now its closer to the gear and I wonder if the is enough room for the small snap ring on the shaft if the retainer washer is between the bearing and the gear? The bearing must move ahead on the shaft.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
