OK, unhook carb link to governor, pull throttle lever to full throttle position. Put carb butterfly in wide open position. Adjust length of rod so they just match. Shorten rod one turn from that so when governor opens up it does not slam throttle shaft in carb against it's stop. (slamming it against it's stop is very hard on the shaft and bushing causing premature wear). Then , when you get it running at a speed where it hunts, screw in that little bolt on lower end of governor housing until hunting quits. A good lively governor will usually hunt just slightly one time when opening throttle from lower speed. If you screw it in too far carb will not idle down. If screwing in does not help, check for broken or loose bumper spring in governor. Lean mixtures or other wise poor tune will also cause hunting.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
