Posted by wayne in mn on May 06, 2014 at 11:07:25 from (66.188.174.211):
In Reply to: Starting my 300U posted by Danby on May 05, 2014 at 22:10:45:
First, accurately locate TDC for #1 cylinder on compression stroke, the points should JUST BEGIN to open at that point. If not, follow the procedure below to set spark timing. Use an ohmmeter with a low reading setting and attach one lead to the points wire going into the distributor body and the other meter wire to the metal side of the distributor body. (I prefer to remove the cap, rotor, & protective cover over the points so I can see what is going on) Replace the rotor temporarily for reference purposes. Loosen the distributor hold-down capscrews so you can just rotate the distributor body. Rotate the distributor body CCW (looking from the operator seated position) until the points rubbing block is on the cam lobe highest part. Point gap is .020”. Adjust as needed. Rotate the distributor body clockwise until the ohmmeter shows that the points are closed. If you cannot get a 0 or nearly 0 reading then clean the contacts with a very fine abrasive and spray some contact cleaner or brake cleaner (no carb cleaner, it leaves residue) and snap the movable point arm with your finger verifying a good, clean connection. You may need to remove the points and clean underneath them. The meter should read infinity with the points open. Since you previously found TDC #1 cylinder now slowly rotate the distributor body slowly CCW until the meter just begins to indicate the points are opening. Tighten the hold-down capscrews, replace the points cover & rotor, distributor cap (the rotor should point to #1 tower in the cap), verify the firing order (1-3-2-4 in the CW direction), and you should be good to go. IF the cap is not cracked, IF the rotor is not carbon tracked, IF the wires are in good condition, IF the sparkplugs are good, all should be well. I like to remove the coil-to-cap wire at the cap and use a jump gap tester to make sure there is decent spark. (1/4” bright blue and snappy). Happy “sparking”.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
