Posted by rhtx55 on April 30, 2014 at 17:06:55 from (68.185.207.25):
In Reply to: steering bushing posted by kathy massart on April 30, 2014 at 15:46:52:
Measure the shaft diameter where the bushing goes & then measure the inside diameter of the new bushing. Most original shafts have quite a bit of wear. Best choice would be to have an oversize bushing machined to just fit your existing shaft, if the shaft has a lot of wear, turn it smooth first, then measure for the oversize bushing.
Steering shaft Ujoints, Worm & pivot gears, worm bearing, wheel bearings all contribute to steering play in the steering wheel. It has been my experience the sooner you replace them all (as one can afford) the better the steering will be.
I have an F300, over time I replaced steering shaft (with gear), worm gear ( full round), steering shaft bearing ( in upper bolster), steering shaft bushing ( in steering tower at platform), steering shaft u-joints, wheel bearings & seals, upper & lower bolster bushings
(had oversize ones machined to fit the turned down original shaft) where the bushing ride, new felts & seals, new thrust bearing ( had the lower bolster machined smooth for it to ride on). You can now turn it stop to stop just by using the spinner. In road gear no wobble & it steers with just a finger.
Wasn't cheap, but was much cheaper than trying to put power steering unit on it !!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
