I worked for 25 years in the engineering experimental lab of a hydraulics company. Every so often in our test machines we would get a leaking heat exchanger. It's darn near impossible to boil all the water out... we would take the lid off the reservoir and heat the oil with the reservoir heaters to about 250 degrees, run the circulating pump (pump for heat exchanger and filters) and it would take days to boil the water out. Sometimes we did not have the luxury of taking that long, so the best bet for us was to drain EVERYTHING, all hoses, pumps, reservoir and put in fresh oil. I realize you can not hope to drain everything in a tractor like that, so I'd drain what I could, external lines, filter, etc., put in fresh and go with it.
Problem with water in the oil is it's like any other contaminant, especially under high temperature and high pressure... it will erode components. A pump with 4-5000 psi and water will erode just like if you threw sand in it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
