Posted by pete 23 on April 18, 2014 at 10:28:46 from (74.33.94.238):
In Reply to: 1486 reverse problem posted by big1486 on April 17, 2014 at 15:56:47:
I see no one has responded to your problem. Here is what is going on. The shift collar on reverse is going too far and slides up on the splines of driven gear so far it comes disengaged from driving gear. Usually caused by worn or broken fork, or key way in reverse shift lever shaft. May also be caused by too much end play in the reverse shaft assembly. Some times the washers between the gears break, wear out or wear into the rear housing. One other thing is wrong gasket installed between speed transmission and range transmission allowing shaft to move forward a little. Need to take off side fuel tank to remove side cover to take a look. Then run over that tank so you can't put it back on and save everyone who ever has to do any work on the tractor a lot of headaches.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
