Posted by The tractor vet on March 11, 2014 at 18:32:29 from (75.19.125.103):
In Reply to: Re: 826 Park Lock posted by Pete on March 11, 2014 at 17:42:00:
All you will see is Rev sliding gear and shift fork under that cover . The deck and shift cover must come off Three springs to unhook clutch safty switch a hand full of 3/8ths bolts on the deck and some shift linkage and park loc linkage on the shift cover . Tools needed for the job 3/4 socket short extension ratchet 9/16ths socket and extension and ratchet a pair of side cutters one still bladed putty knife SHARP and a hammer . Now if said tractor has side hyd. couplers on the dash support them you will need a couple bigger wrenches . a use the putty knife to drive under the shift cover in the corners to break the gskt. and a couple small pry bars . Like i said before IF it has the spring loaded park lock ya need a 1/2 inch nut to place under the park loc to hold the rod up . Also make sure the shift linkage is in Neutral . Once you have it all off NOW is a good time to check all the stuff on the bottom side of the shift cover . Best to get a I T manual .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
