Hi Andrew, 574 and 454 are same hydraulic, from the archives: Hi Joe, on the 454, the oil pump feeds the steering in priority, then the remote, hitch, PTO and brake. The flow-divider valve give 3 GPM to the power steering and 9 GPM to the hitch system. When the valve is stuck in the bottom, you have no power steering, no PTO and if stuck in top, you have no hitch, no remote. Remove the plug and the spring, put a container under the hole, start the engine and pull the remote lever. The flow-divider valve goes out in the container. Sand the valve with a 400 sand-paper and try again. Change the filter if it's old. Maybe you have dirt in the oil, check in the filter housing when you open it. When the filter is full of dirt, it has a by-pass valve that opens and allows the oil to go directly to the pump via a screen. In this case, dirt can go in the system and cause your problem. Hope this help you. Bernard le mécano Québec Canada
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
