Posted by eastsider on February 16, 2014 at 13:25:28 from (24.111.75.41):
Since I see a lot of questions over the years about how to remove the old, rotten exhaust pipe from the manifolds, I thought I would share the procedure I always use. I am restoring my H right now, and had to refurbish the manifold recently.
Step one...carefully use a Sawzall to cut through the old pipe...this can be done either on or off the tractor. This one happened to be off.
Step two: Make a couple of careful cuts into the threaded area with the sawzall again, being careful not to cut into the manifold if possible. Once done, chisel out the small chunk and the rest will peel right out.
Step 3: Wire wheel, bead blast and scrape, scrub etc... Make sure to clean out the drain holes on the bottom. They are more than likely plugged up! See the difference? Then clean out the threads...use a pipe tap if you have one, or a dremel tool works well too.
Clean it inside and out, I use brake cleaner! Blow it clean so all the glass beads are gone, and reinstall. I don't know what the markings here mean...did I really find an M&W replacement manifold, or are these casting letters from IH?? There was an IH part number on it too. Any thoughts??
I hope you can use this for your restoration someday!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
