I'm sure the key way and the bearings can be gotten from Motion Industries pretty easily with a little part number research (or use numbers from old ones). The bushings can be made at a machine shop if you'll remove the upper and lower castings. The gaskets should be really easy to get.
If you wanted to convert it over, get a good used shaft on eBay or parts place, then the new rebuild kits are EASY to get (for about $65.00) and come with bushings, seals, bearings, and gaskets.
DO NOT use parts from an old unit if you are rebuilding....swapping the whole front end is a different story. Will be like new in the end.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
