Posted by JC3 on February 02, 2014 at 09:17:02 from (205.243.121.118):
I ordered main crank shaft and rod bearings for my 460 here. The number 3 main crankshaft bearing has a wider side flange than the one I took out and I am not able to get the new bearing to slide in around the crank. The number 1,2 and four go in fine. I checked my clearance with plastigage on the new bearings at .oo2". The bearings I took out are standard size so that"s what I ordered back. I did see in the I&T manual that apparently they changed the thrust bearing surface from 3 3/4" to 4"on later models but the diameter on the new bearing and the old bearing are the same. The only thing I see different is the side flange. My question is, why does the thrust bearing not fit? Thank You.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
