Take the panel, under the steering, center at the floorboard out. It's held on by two bolts at it's top.
With the aid of a good light, you can see the shift linkage down on the top of the transmission thru here if you stand on your head & hold your tongue just right. :>)
Either one of the little clevis pins has jumped out of the linkage OR the roll pin has sheared on that hi-low vertical shift shaft.
Since the tractor is stuck in hi range, it is 'probably' the roll pin. If ya remove the right battery it makes it a bit easier to replace.
Now, the problem could still be up on top at the little tie-rods behind that shift quadrant housing, but "usually" it is down below.
If the tractor has the factory cab, the difficulity level jumps by a factor of 10.... :>)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
